SF Vibro Champ fuzz
  • SF Vibro Champ fuzz
    Hi !
    My 70's silverface vibro champ is fuzzing with lower notes : it's not very loud, but i clearly hear it, and if i let the note last longer, i only hear the fuzz sound .... i tried to change the valves (i put back the old ones, that still worked fine) with no change - also tried with another guitar - the speaker is new (jensen)
    may i have a look at the caps ? another idea ?
    thanks a lot !!!
    Originally posted by rokplo View Post
    Hi !
    thanks a lot !!!
    According to what you have posted, I don't like to guess unless I have the amplifier right in front of me, but even though the speaker is new, try another one just to eliminate that problem. I could quote twenty other problems, but like to stick to one at a time.
      I would also consider the speaker. Did it make this noise before you changed the speaker? Try connecting the amp to a different speaker.
      Just because it is new doesn't mean it can't have a defect.
        If the new speaker's mounting nuts are too tight, it can warp the frame. That can make the voice coil rub and cause a sound like the one described.
          The speaker is new, but i plyed one year without a problem ;-)
          When i say "new", i just mean it"s not the original one ....
          the sound is really like an electronic fuzz (like a pedal effect) ... any suggestion ?
            The fuzzy buzz in my ex-VibroChamp was caused by the speaker.
            Not that in your case this has to be the culprit...
            Carlo Pipitone
              it really doesn't sound like a speker buzz for me ... i tried playing while touching the paper of the speker, and the fuzz was still there ...
              it sounds "electronic" really like a pedal effect - it's near the "seven nation army" sound (but of course not as loud - just a little bit in the background)
                i took out the amp from the cab and tried to move the caps/wires inside with no result. With the amp out of the cabinet, the fuzz is still here.
                The board has bulged in the middle, and has a big wave - maybe the board material has become conductive ??? not sure that theese 70's boards could have such problems ?
                I think i'll try to heat all the solder points on the board to avoid cold solders ?
                any other suggestions ?
                Thanx !!!!!!
                  I heated all the solder points on the eyelet board with some new solder .... and no result, this fuzz is still here ....
                  Help !!!!!!!! i need some experts advices ;-))
                    Try a different speaker and see what happens.
                      i 've taken the speaker out of the box to examine it : it's perfect, the cone shows no default or scratch - it's new, less than one year, and always sound perfectly .... so i don't understand why it could suddenly fuzz ... the fuzz sound is there, whatever the voume level is - it just grows up with the volume.
                      I don't actually have another 4 ohm speaker to make a test ... i could eventually try with a 12' 8 ohm speaker .... is it dangerous for the output tranny ?
                        no, just as long as it's not a lower impedance speaker. try it with the 8 ohm.
                          Have you changed the tubes to "KNOWN" good tubes?
                          Mandopicker
                            for the preamp tubes, yes . For the power and rectifier tubes, i used the old tubes that were in the amp when i bought it. There were no fuzz at that time. When i changed the tubes, i had EXACTLY the same fuzz sound ...
                              You should *definitely* try a different speaker (the 8 ohm will do) before chasing the buzz elsewhere...
                              Carlo Pipitone
