My DB switches when switching with the channel button but when I plug in a 5150 footswitch it goes to the clean channel and wont switch. I figure the footpedal is wrong but my question is this. As long as it switches manually when i get the right footpedal it should work, correct?
Delta Blues Not Switching
The footswitch isn't complicated - 2 stomp switches wired to a stereo (also called TRS) 1/4" plug. Each switch connects either TIP (Tremolo) or RING (channel) to SLEEVE (gnd).
The right footswitch should still work if channel switching works at all. You could make your own, too.Attached Files
I know it sounds like a stupid question, but have you got the channel button pressed in when you hook up the footswitch? (As you probably are aware - if it ain't pressed, it overrides the footswitch)Building a better world (one tube amp at a time)
