Hi, I have a 65 twin reissue and there is a nasty problem with the vibro where it cuts in when loud notes are struck then stops as the note dies.
Just to be clear, the amp is set with reverb and vibro OFF. When you strike a note quietly everything is fine. When you strike a note hard the vibro cuts in but then as the note dies it turns itself off.
This problem happens if the footswitch is plugged in or not. Also, I have THREE different footswitches, all of which work perfectly well in a seperate amp.
The speed of the vibro is consistent with the speed set on the amp, e.g. if it's set at 1 and 1 then its not noticable, but when its at 10, 10 its a nightmare. This leads me to believe that its some sort of switching issue.
Tubes: All of the preamp tubes have been replaced.
Help!![Mad](https://music-electronics-forum.com/core/images/smilies/mad.png)
Thanks for looking.
Help!
Thanks for looking.
