This amp has good signal out of the preamp out. I tried swapping in new tubes, I've checked the bias supply and get -45v to -55v when adjusting pot on pin 5 of power tubes. Phase inverter has these voltages:
1-272
2-27
3-42
6-260
7-28
8-42
There is 466v on plates and thereabouts on screens of both power tubes. Cathodes are indeed grounded. I suspected a bad B+ filter cap and when I tested one it was indeed bad so I replaced it. Now there is still very low volume and distortion when I crank the clean channed volume all the way up. I'm left thinking the OT is bad but I measured the primary and get 58ohms on one side and 62ohms on the other. I disconnected the secondary from the output jack and measured for shorts to the core and nothing. Is there another test on OT or are these results sufficient to think the OT is fine?
1-272
2-27
3-42
6-260
7-28
8-42
