Is this a solid state amp or tube? Are you talking about the bridge rectifer section of the power supply? Voltage and current ratings are all you need to know for a suitable replacement. You can make an educated guess by looking at the main filter caps voltage rating. Watch the polarity when you replace it. Also it may be a Zener diode for the low voltage rails in a SS amp.
there was a burnt disc cap in the ps . However , with all the sec wires disconnected off the trans, i get a little smoke , heat and a burning smell from the Transformer.
I've got a RH300 here at the shop too with the exact same problem "smoked tranny". Let me know if you have any luck getting a schematic from Randall. They wont give me one unless I'm a dealer or warranty center.
I'm afraid I'm going to be stuck with this one for salvage. I would bet the tranny is about $150 plus shipping.
