3-prong cord for Fender Champ
  • 3-prong cord for Fender Champ
    Just wanted to know if I could get some advice on installing a 3-prong grounded cord to my Fender Champ. Thanks!!!!
    Hi.
    Hope I can help you. I have a (diy) champ of my own, with a 3-prong grounded cord. I made it so that the ground is directly connected to the chassis by a short (2in / 5cm) ground wire (just an ordinary wire).
    you should make sure that there is a good and solid connection between the cord and the chassis.
    Hope that helps
      Sir 6V6, When you mentioned the ground to the chassis are you referring to the green wire? Thanks, Rayme
        How about this?
        Stop by my web page!
          Regis, Thanks for the schematic, very clear now and no more confused little face on my post! Checked out your web site and was amazed at the huge amount of info. I will be spending some time there. Thanks Again for all the info, Rayme
            I think this is the safe way to rewire it:
            Fender amp AC cord conversion
            This moves both the power switch and fuse to the black wire. If there is a ground switch then many people use the switch as a standby as you would not use a ground switch any more.
              Hi ddr, welcome to the forum.
              yep, that's a good tip.
