New to the forum and to amp repair so please be patient. I am learning a ton from this forum and am happy to have found it.
I have a 1965 Gibson GA-5T Skylark amp that had a resistor burn up. I will be replacing it. I want to replace the original wax and paper capacitors. The schematic only says 20uF for the capacitors. My question is, how do I determine what voltage to use? Sprague 500V are $8.00 and 450V are $6.00. Can I use the lower voltage capacitor?
Also the schematic shows 4 20uF capacitors and I only have two paper ones. I don't think there was a hack job in it as they are in metal band holders that are riveted to the chassis and nowhere do I see that any bands were removed. There is one white ceramic looking rectangular part which can been seen to the lower right of the large capacitors. What is this? I am not at home so I can't give you the numbers. I can update this post tonight with a better picture of it and the numbers.
The schematic can been seen here: http://music-electronics-forum.com/s...ead.php?t=5465
Thanks for the help. Cool little amp when it is working right. Here are two photos (cell phone camera sorry).
