I am replacing the power board in a TOA A-912MK2 PA amplifier. I'm a little confused on the written procedure for setting the idling current on the amp. It seems I am to take millivolt readings across each of the 4 power transistors' emitter resistors with the power off first??
Then if the readings match those in a temperature table, I am turn on the power and set the control pot to achieve the readings in the table. That doesn't seem right. Should I get identical readings with the amp on and the amp off? Am I misunderstanding the instructions? Am I to check the idling current at the emitter resistors of all 4 power resistors both times and set for an average of the 4? I've attached the instructions and the schematic.
It seems to me that I should set the control pot full CC, power on the amp, check the 4 Q's emitter resistor voltage drops in mv, adjust to the match the table reading at ambient temp, then wait 3 to 5 minutes before readjusting. So for instance, at 77 degrees ambient I should be aiming for 4.4mv across the 4 emitter resistors. All of this with zero signal and no load right? Or should I have a 41ohm 200 watt load resistor on the 70 volt output and a 1kHz signal injected for the idle current set up like is done for the distortion adjustment.
Thanks for any help in advance
