Alright, I've done quite some work to my JCM 800 2205 head. I've modded it quite a bit. According to this thread:
http://music-electronics-forum.com/s...ad.php?t=10329
Everything went pretty well. But right after I installed a 10uF/50V capacitor across R25 (1k5) in this schematic, my amps started to drop in volume. Polarity of the installed cap is correct.
http://www.schematicheaven.com/marsh...h_50w_2205.pdf
When I turn it on, all the tubes light up, and when I turn standby off so I'm ready to play most of the time the volume of the amp is much lower than it should be. Sometimes the volume bursts up and I can play for a few minutes on proper volume but most of the time it's pretty quiet. Is it the cap I used? 10uF/50volts seems right to me...
Any help? Is this the tubes? My solders look good to me, but I'm not sure what the problem is.
