Marshall AVT50 Valvestate 200 Combo blowing main fuse
  • #31
    OK, for some reason my AVT50 file includes a digital reverb board, but now that I look, my basic schematic is the same as yours.
    So remind me and us what we are looking for in the reverb?
    • #32
      As I got this chassis as a already molested(unsuccessful repair attempt) it was missing the power amp board and reverb tank. The only thing I found for reverb is a 4 pin connector on the main board. I want to know if I can use this connection directly to a reverb tank. As in a cable from the 4 pin to the rcas of a new 8DB2C1D?
      • #33
        The block diagram shows IC1A driving the tank & IC1B recovering the tank.
        avt50_Block Diagram.pdf
        • #34
          [ATTACH]39425[/ATTACH]
          So am I right in assuming I can attach the spring rcas directly to the CN2 4 pin connection? And figuring which side of the connection is drive and recovery.
          • #35
            Yes.
            It is simple to figure it out. The op amp on the left, IC1a shows its output pin wired to CN2-4, that is the hot to your pan drive, the jack marked INPUT. Pin 3 of CN2 is the return from that jack. Note it is not grounded.
            CN2-1 is the hot from the return jack, the one marked OUTPUT, note it feeds an input pin on the op amp. CN2-2 is the ground from the pan output jack.
            • #36
              Thanks
