I am new here so I would like to start by saying Hello to everyone.
I found this site by searching for help with Marshall AVT amps so I hope I am in the right place. Sorry but this is going to b a long post.
I have a Marshall AVT150H serial number M-201-38-1305B about 6 years old.
A problem started one day with bad sound on the OD channels then the next day no sound from OD channels Clean and Ac Sim ok. Next couple of days a bad hum started and the leds on control panel not working properly. They glow dim and all on at the same time also leds on foot switch don't work.I tried disconnecting foot switch no change.I tried replacing the tube but did not fix the problem. Also the Effects don't work now.
After reading some threads here I looked at the output drivers with the TDA7293 chips. I thought the one on the right (with control panel towards you) may have had a burnt spot so I unpluged both connector (all connections have been done with Power off first) turned Pwr on no change still hum and leds funny. Unpluged other output driver connectors. The hum stopped probably normal. Pluged the right driver only in turned Pwr on got a loud squeel. Turned Pwr off quick. When reconnecting right driver Found it was a little loose on heat sink, took it off for better insp. looked ok what I thought was a burn was onlt a piece of trash maybe plastic. Reinstalled it also tightened the driver on the left. It really was not loose. Turned PWR on got loud squeel and pop and Saw a flash the left TDA7293 burnt.
Have any of you had this problem? Would the TDA7293 chips cause trouble with the effects and leds on control panel and foot switch along with output problems? I know I need both TDA7293 chips now. Before I replace them where else do I need to check for trouble?
I also need a fan. It is noisy for a few secounds on Power up then Sounds ok but can feel a sligth vibration in it the other is ok. Where can I buy them.
Again sorry for the long post but I want to give all the information I can.
Please help if you can
Thanks Force3fan
Thanks Force3fan
