I have a '69 Fender Twin Reverb Silverface that has worked fine for the past year. A few days ago, after warm up and then switch on, it emitted a strong hum which started to build into a howl. I switched the standby switch off immediately. It feels as if the hum will eventually destroy the speakers (starts soft and then builds).
Started replacing all the smaller tubes (preamp tubes) but no luck so far.
Amp had 7205/12AX7's in and 2 x 12AT7's in the correct positions.
Any clues as to what the resolution could be?
Should I replace the output (6L6's) tubes as well?
