I happen to have two Fender amps in for repair this weekend. One of them is a Red Knob Twin and the other is a Deluxe 112 plus. Neither of them had a footswitch and I am fabricating them from generic two button Marshall style footswitch boxes since everyone was out of stock on the Fender unit.
Both amps use the Channel Select/Reverb type Fender footswitch. However, they differ in the polarity of the diodes in the footswitch (and inside the amps' switching sections) that are assigned to either function according to their individual schematics. It would seem that there would have to be two different Fender footswitch models (one for each amp) in order for each particulary labeled button to operate the properly related amp function, and that these two pedals would not be interchangeable.
I have attached both schematics. For the reverb switch on the deluxe 112 plus, the cathodes of the led and diode are assigned to the tip of the plug. For the Red Knob Twin's reverb switch, the anodes of the led and diode are assigned to the tip. This diode polarity carries through to the circuits in each amp as well according to the schematics.
So my question is, would Fender really do this and not have one pedal work for both amps?
Edit: Now to make matters even stranger I find that on Fender's website they show one pedal part number for both the "The Twin" and for the Deluxe 112 Now, I'm wondering which layout to use to make these work. I guess I'll just go with a coin toss.
