This amp came in with a bad input jack.. so I replaced it and that's fixed. Then I was checking voltages and there was -450mv on the grids of the 1st 2 preamp tubes. I read another thread that ended in replacing bad coupling caps so I replaced C9-12 and that grid issue is now fixed. However there is now a bad high freq oscillation AND crackle when the amp is turned up to a certain volume. This happens in both channels and is only if signal is being run through it and the amp is at a certain volume. Bias on power tubes is good. I tried new power tubes and the 1st 2 preamp tubes in the chain are new 12ax7lps. I will try other preamp tubes and see. If anyone can suggest what this might be I'm all ears.
Oh I also retention all sockets and poked around the components w/ no issues there.
