I am overhauling a Silvertone 1472 amp. It's very similar to the more common 1482 with just less volume (maybe due to lower voltages in the power supply section?).
This amp has a weak tremolo: I can barely hear it even with the strength pot set at 12. Also, there is a 4-5 seconds delay when I turn the strength pot to max before I can hear the effect.
Voltages are in specs all over the chassis, EXCEPT on pin 6 (grid 2), where I have 42 instead of 75 VDC.
Can this explain the weak tremolo? What can cause such lower-than-expected voltage? I have tried a different NOS 6AU6 to no avail.
I have also replaced all the components around pin 6 (R30, R31, R32, C14 and C15).Schematic is attached.
TIA,
Carlo
TIA,
Carlo
