Hey guys/gals,
My first post here. I have a '04 model Workingman's 10 and while playing it I heard a pop and the amp went completely silent (no sound at all through the speaker). Took the chassis out and the fuses are OK. I noticed that the cap marked with C6 (10UF) has exploded/vanished and the power amp IC attached to the heat sink U1 (TDA7294) has partially melted. CORRECTION: The IC is not actually melted but it is damaged due to the exploded C6 I guess, I found pieces from the black substance from it on the bottom of the cab.
Small additional detail: I was physically turning the amp to look at the back of it when it "popped".
What do you recommend me to correct the problem? I live in Atlanta, should I take the amp to a SWR tech (if available) or should I get new parts and try to fix the problem by myself? I can solder and read schematics. BTW I bought the amp used a few days ago and straightened some components on the PCB, C6 MAY have been one of the components I touched but I am not sure.
I can post photos if they would be of any help.
Adding: When the output switch is in the "phones only "position I hear only hum though the headphones. The other two positions are completely silent though phones too. I get the signal to headphones though effects send and tuner out jacks.
That vanished C6...is it 50V electrolyte as its neighbor C5 is?
All in all, should I simply get a new TDA7294V and C6 and turn the amp on to check if it works?
Thanks, in advance!!
PS: Partial schematic posted by acorcos in this thread:
http://music-electronics-forum.com/s...workingman%27s
