Need help with marshall 6100
  • Need help with marshall 6100
    Hi folks,
    I'm new to this forum and I wantet to ask help for a problem with my marshall anniversary 6100.
    Some time ago a valve was burnt and I replaced all four. But anyhow the amp does not give any sound ... all lights are on and the valves seem to be alright as well. Could it be the main fuse?
    cheers&thanks
    Fuses are the best place to start. Schematic shows 2 fuses on the incoming AC power and 4 or 5 inside the amp. Also check that the plug/socket cable connectors are tightly connected. I've never been into one of these amps. It appears that there are several "connectors" between different parts of the circuit.
      thanks for the answer!
      i see three fuses from the outside 2 have signal lamps but they dont light up, and another one which i guess is the main fuse... i will check that one for first before opening the amp... all i have to do now is to check which fuse is the right one for the amp... does marshall use always the same fuses?
        I wonder if one of the two AC fuses is inside the body of an IEC socket???
          oh I dont know about that, i have to open it but first i try to replace the fuses from the outside...
            not sure if you have this type of power cable connection. If you do, there's a small fuse inside, accessible from the outside. Not a picture of your amp, I know.
            http://www.jacksonampworks.com/images/uj_fan.jpg
              Thanks Gunny
              Yes, it looks like that pic. I found the users manual for the amp...
              http://www.marshallamps.com/download...niv.%20hbk.pdf
              in the end you see the back panel and the fuses its very similiar to the pic you posted... do you know what kind of fuse goes with this head?
                from the schematic for the power supply http://www.drtube.com/schematics/mar...6100-65-04.pdf
                there's a 20 mm fuse rated 5A (T5A) and a 20 mm fuse T2A (2 Amp for 230 Vac operation) or T4A (4 Amp for 115 Vac operation).
                To confirm what you need, unscrew the cap from the conventional fuseholder and see what's inside...and see if it's blown. Similarly, pry open the fuseholder built into the power plug and check out the fuse that's in there.
                  thanks a lot for the help, i will check the fuses the next time i get in the rehearsal room... if the fuses are ok i will check the connections!
                  casinolevant levant casino
