Hi, I've had a Traynor BassMate for about 15 years. It's always had some issue that I could ignore by merely cycling the power and getting it to settle in. I hardly use the amp. It's real clean but getting old.
The other day it finally seemed to die and only made a farting type sound.
I pulled the chassis. All I can find wrong is that the EL84 tubes are blackened with what I assume is getter material. The circuit itself seems stable.
It's all original caps etc... maybe a fresh bias supply cap was installed a while ago.
I placed two new Sovtek EL84s I had on the shelf and it just sounds great. better than ever.
So I went ahead and checked some voltages. They all seem stable but a bit higher than I expected.
I don't know what else to do preventative maintenance wise. I'm wondering if the tubes just finally wore out (I've never seen them so black) or if there is some other failing componet I should suspect as the real casue of the problems.
I can do a cap job but the amp is so clean right now... I'm hesitant to do a cap job just for the sake of it.
I'm seeking advice about the voltages. The B+ seems high and the -18vDc at the cathodes is about half of what I'm familiar with 6v6 circuits.
Here's a link to the schematic that I think applies to my amp, I've notated it with the voltages I'm measuring:
http://harmoniccycle.com/hc/images/g...ate-YBA-2B.gif
best regards,
mike
best regards,
mike
