A friend dropped off a "Musicale Coronet" 1953 record player. I removed all of the very rusty and drifted internal circuitry (it's a tight fit, makes the filmosound I did last month look easy) to build a nice little blues amp out of it. It used a 6x5 recto, which sounded like bad news in a music amp that gets banged around, so I redid the circuit with a solid state full wave into 100uf. The amp powered up with the new design ok (redid power and PI so far, replacing everything) but with "objectionable" hum (120hz). It plays music well, but during silent passages or when the input is grounded, it hums. Same with PI pulled, stops when power tubes pulled.
So I started poking around in the power supply, and I noticed that the resistance between B+ AC leads and ground is very, very low. There is no center tap, but they were using the 6x5 full wave. IS the transformer itself being used as the center tap? It's not shorted (I believe) because I'm getting around 400v out, which seems reasonable. I also measure an AC offset between chassis and myself (24v) and a 7.5v between chassis/transformer and ground. What's the deal? Is the transformer itself the B+ center tap? Both B+ leads went to 6x5 plates in the original, but no center tap was present. Weird. Any ideas out there?
I should note that the resistance is still low with transformer out of circuit. Thanks for any help you folks might have!
