I know this sounds weird...
I have a Hughes and Kettner Zenamp head on my bench. It works OK, but for some reason the pilot light will flash on when you first start up the amp, and then go out and stay out. It's not a #47 bulb, it's three blue LED's in series with a 1500ohm resistor on a little PCB. I checked the volts in, and got +21v on the hot wire even when the light was out, and ground checks out OK.
I can take out the pilot light board assembly and light it with the analog power supply on my Tek bench, so it's OK. I have what passes for diagrams, they only go to 'board level' so they are no help at all.
Anyone else see this one, what did you do?
Ken
Ken
