I had originally replyed to a post about a Blues Jr. with a redplating problem but figured I would start a new thread.
I noticed the EL 84 output tubes redplating in my Velocette so I first tried installing new tubes but they also redplated. The plates don't fully glow it is more of a small streak of red. A tech friend of mine checked it out for me and said I had 0V at the grid and to check for cold solder joints which I did and touched them up. I then tried another pair of new JJs and they also redplated. I have an old pair of JJs that rattle but run without redplating but all the other EL 84s including some NOS Sylvannias g0 red.
Enzo suggested checking the plate current dissapation and I came up with 18.6 watts. Please bear with me while I show the math to make sure I did it correctly. The cathode resistor measures 120 ohms and 12.5 V at the cathode = .104 / 2 = 52 millamps. I measured 370 volts at the plates which 20 v higher than the schematic I figured the anode voltage by subtracting the cathode from the plate and got 357.5 V. Then I multiplied the estimated anode voltage by the cathode current and got 18.59 Watts.
I'm guessing the 20 extra volts at the plate would only account for 1/2 a watt or less so does the value of the cathode resistor need to be increased? Or did I do the math wrong?
Thanks in advance for any help.
