hello everybody... i discovered this forum last night after attempting a google search for a free schematic to this particular amp (which i was unable to obtain). i just started a side job as a technician at a local music store.
on the amp in question both speakers are good, and when i use the headphone jack i get the same result: one channel functions properly with the other one being barely audible.
when i try the chorus function i'm not getting any sort of "phasing sound". all of the potentiometers in this amp appear to be in rather immaculate condition.
not having had any prior experience with this amp, i opened it up and did not find any burn marks or anything out of the ordinary... except i had seen where the previous owner had poked around inside a bit and reinserted one of the ic's with one of the legs bent outside the socket therefore not making contact.... the ic in question appears to be involved with the chorus circuit which does not appear to work. naturally, i re-inserted it properly. apologies for not having noted which ic this was but i can have this information when i get back to the shop.
regarding the issue of the non-functional channel i did the best that i knew how without a schematic, which was to try and compare measurements of the transistors in the bad channel to ones in the good channel... i did this without power using the diode checker in my meter. off the bat i wasn't able to encounter anything significantly different when comparing the two channels. i did not measure any voltages of the transistors either. everything functions fine except for one channel, and the chorus.
any help would be GREATLY appreciated. i can have more specific answers to any questions after getting back to the shop today (friday) where the amp is.
thanks in advance,
mike
thanks in advance,
mike
