I just received a Supersonic for repair. The customer said the amp has low volume and distortion on the clean channel. After a preliminary inspection for obvious mechanical issues, I noticed EL34 tubes plugged in. The tube reference sticker in the cabinet says 6L6's as does the schematic. I checked the tube socket wiring and there is no connection to pin 1 which I believe is the suppressor grid. I also understand the EL34 draws 1.5 amp heater current while the 6L6 draws 0.9 amp. And I imagine the bias requirements are different.
I did a web search and turned up one reference on a forum from a user that said, "don't do this swap". Does anybody know if this is a valid substitution?
