![Fire](https://music-electronics-forum.com/core/images/smilies/AR15firing.gif)
Enzo- I powered up the unit today in order to test the pre-amp. I plugged the monitor out and L,R out seperately into my guitar amp and with a microphone tested the mixer. Channels 1 thru 4 seem to function OK 5&6 have no output.7,8,&9 have a weak signal and no monitor out. #10 has a good signal. The unit starts to smell hot after several seconds and I can't find the source. The Ic's and visible components on the mixer section all look OK and no sign of burning or smell of smoke. The amp section however has a large black patch and lots of smoke damage at the site of the lower amp between the two heat sincs. Also on the reverse side of the amp circuit the IC6 is burnt. Everything else on this side of the board looks OK. There are 5 other surface mount Ic's on this panel do they have any relevance to the pre-amp. Ie: could IC6 control the output for channel 5&6? The IC6 is so badly burnt that there are no visible #'s Can you provide a part # or sell me that IC? My thought is to replace IC6 and maybe get the mixer working properly before we proceed to next step. How can I make sure the power is cut to the amps to ensure that nothing else burns? I removed the fuses and the whole unit is dead. Thanks for now....BRANT
