Crown CE2000....anyone actually repairing this junk?
  • Crown CE2000....anyone actually repairing this junk?
    Got a CE2000 in that was damaged by running it in the wrong output mode (I think it was set to bridge with stereo spkr cabling, maybe the opposite) and took out a whole bank of output devices. There's SMT stuff blown up all over this thing....all the emitter resistors (1/4w smt....how are they getting away with this??) are open on the bad bank....other smt transistors and resistors....who knows what else. There's really no way to work on them without taking *everything* out of the case and strewing it all over the bench. With the hot heatsink design that's not my idea of fun.
    I'm thinking its not worth the hassle. Pass....parts carcas.....
    When I get stuff like that, I try to find out how much a new board would cost from the manufacturer and then mark it up 50% and tell the customer how much for the repair...usually they pass on it....if they don't and DO want it fixed, it's usually a board swap / an easy fix and you make a few bucks.
    Some companies won't sell you a board either because you're not an Authorized repair center or they just don't sell fully populated boards to anyone, regardless of who you are. In that case I just call the customer and let him know it isn't worth fixing.
      Since they're discontinued, I doubt they (Crown) want anything to do with them.
        Wow! What a change from the old days when Crown was looked upon as "state of the art". So much for progress.
        Mac/Amps
        "preserving the classics"
        Chicago, Il., USA
        (773) 283-1217
        (cell) (847) 772-2979
        Now back on Chicago's NW side in Jefferson Park!
        www.mac4amps.com
          Had a CE 1000 ages ago with the fan circuit kaput.Replaced the smd MJD112 but that was all that was wrong.
          At the time I saved some coments from a forum that no longer seems to exist. So here from my personal wayback machine...
          I see a steady trickle of these things with amps totally FUBAR.
          Crown is meant to be a reputable outfit, but often there does not seem to
          be any evidence of user abuse, so it kinda points to a design flaw. When
          they go bang they REALLY go bang, and often take out the wooffer as
          collateral damage. Rebuilding them takes forever, and there's always that
          nasty feeling that, not knowing the cause of the original fault, they may
          do it again.
          Anyone have any idea why they fail ? M
          (picture also attached oc)
          Ouch !!
          It is a bit hard to tell from the Photo but those aren't the Emitter
          Resistors are they ???
          R wrote in
          No they aren't :-) They were before they got vapourised - 2 * 2512 (1
          watt) per output device. Tis the only time I've ever seen these tiny
          critters used in this application - they don't cope well when the MJ's
          head south.
          M
          M wrote:
          The CE1000/2000 series amps are known to be somewhat weak amps,
          especially for sub duty. The CE4000 is a different animal and is more
          up to the task. It is not the same design as the other two. I would not
          recommend smaller model CE series for anything other then higher
          frequency applications at higher impedances - no lower then 4 ohms
          stereo/8 ohms bridged. Do yourself a favor and get something more heavy
          duty for you subs.
          R
          M said
          No they don't!
          I have fixed countless CE1000/2000 Sometimes if it's a warranty job you can
          talk Crown into a new board. I was also finding many vaproized traces
          also... WATCH FOR THESE!!!!!. I always felt bad sending these back out.
          Some reasons I found for failure:
          NL4 to 1/4 adaptors in bridged mode or wired improperly.
          Operator error, it's a low end amp and lower end users tend to be DJ's
          running the hell out of them.
          It's not a 1000 watt amp, it's 225 a side, and will be damn lucky to do this
          for very long. Crown started using a limiting system, when in these
          limiters (like all limiters) the average power is raised. They don't seem
          to be able to handle the stress.
          If something goes south in a die-hard true component amp then it will go
          into protect, the smaller components (SMT) tend to go fast and do a good job
          at the cascade effect.
          Crown has had MANY updates, study these and watch your serial numbers. I had
          all the updates printed out above my bench
          If the amplifier is run within spec, no clip lights, they will run a long
          time. If you run it like it's not yours it's going to cost 'ya.
          I never agreed with a 2 watt total SMT emitter resistor, I'm not saying it
          won't work on paper but in the real world.......
          Best use of SMT in a inexpensive amp I feel is the RMX series, SMT where
          it's applicable and thru hole where it's not.
          Nice pic! Does the bottom of the case look like someone dragged a welding rod
          around it? If not then they didn't do it right
          Other reason's for failure I have found:
          Renegade screw under board, from another amp in the rack, big holes in front
          you know!
          Dirt, these baby's will get hot!
          Fan failure and fan control failure.
          overvoltage 220V in USA, DUH!
          They get cranky when powered up and and come out of protect when lots of
          signal is applied (breaker trip, protect re-init). I know but it happens!
          One ot two oscillated, found grounding torx has come loose.
          Good luck, I feel your pain! C
          C W wrote:
          There is no reason why a protection circuit should not work reliably,
          unless its incorrectly designed. I have seen many incorrectly designed
          protection circuits though.
          It should not do this.
          It sounds like there are main design faults. If you can post the
          schematic, I could probbaly tell you whats wrong, if I have the time:-)
          K A
          Read, a limiter run on the ragged edge raises average power. Many of these
          users are running them on the ragged edge. Yet another good example of how
          being a desk engineer differs from seeing how the real world treats gear.
          Should not do what, run reliably if operated within it's specs? SMT
          components have a higher speed of heat rise and decline due to their lack of
          surface area, to design a protection circuit to deal with SOA of ALL the
          semiconductors would bring the amp beyond it's price point. People are just
          hitting them too hard, too fast.
          Don't need a schematic, flip one over Don't have to be a design engineer
          to go, "oh dear god" You probably will not find a fault with your
          calculator, Crown has some great engineers, they just missed this one on the
          price-reliability-who'sgonnauseit ratio. If you are what you say you are
          then you will see the faults immediately if you have real world feild
          expierience. C
          Yup, they tend to look like my first "Hell I can do that, it looks easy"
          adolescent attempts to arc weld rust holes in the mudguards of a Hudson
          Terraplane !.
          I have a couple of intractibles that are doing this, one on one channel,
          one on t'other. Customer cupport has been interesting - Crown have said
          go away, not our problem, call JBL (as these particular specimens are out
          of 418SPs), JBL simply remain silent.
          Thanks for your thoughts, C
          M
          "M D" said
          I have seen that and found a burnt trace going to a "snubbing cap" just
          after the pre driver (I think). Can't even remember location since I
          stopped working on these a year and a half ago. Rarely I have seen the cap
          go bad but it's usually the trace.
          The oscillation I was referring to was a flat out "take off and run like
          hell" till the protection kicked in. Usually too late for the SMT gain
          stage.
          Any burns on a JBL VC and it's "no soup for you" VERY strict warranty
          policy. I have seen loyal JBL customers turn away from the brand in favor
          of a more "Liberal" warranty policy. Been run head-long into that fence a
          few times also. Fun to be the middle man eh? BTW I am still a JBL user,
          never burnt a coil though
          Un-pertaining to the CE series....Think about what a cone goes through
          during ODEP limiting, food for thought......"no soup for you".....again.
          C
            That level of damage is almost impossible to repair on a CE2000. The CE1000 and 2000 were all board swaps at that level.
            Crown no longer carries the Main PCBA for that amp, but we have two in stock if you want to purchase one. PM or e-mail me.
            John R. Frondelli
            "Mediocre is the new 'Good' "
              C[/COLOR]
              HAH! The picture says it all.....same thing I have here......<laughing>.....
              Whatta buncha crappity crap crap!
                Ouch, that looks pretty burnt up.
                I think the problem started when Crown brought out a budget range. They needed Chinese crap of their own to compete with the Chinese crap sold by Samson, Tapco, Behringer and so on.
                As far as I know the budget amps weren't even designed by Crown, the design was outsourced. However this is just a rumour I heard.
                  Actually, the CE1000 and 2000 (same topology; the 2K uses higher supply rails and more devices for higher wattage) are pretty much an updated version of the old, reliable DC300A design, and ARE Crown-designed. Crown designs ALL of their own power amps, including the new xTi-series which replaces the CE1K/2K-series, which originally replaced the PowerBase series. The difference with all of the new stuff is that surface-mount technology makes it more economical to board-swap than troubleshoot.
                  John R. Frondelli
