crate bl120 crashes
  • crate bl120 crashes
    in the middle of playing lost all sound thru amp but still seems to have power on.
    IF you still have power then did you test the speaker?
      no i didnt how does a guy go about that
        amp
        You can do it with a meter at low ohms or take the speaker wires from the speaker and touch them to a 9v battery see if it make a pop noise
          thanx for your input jam. iplugged into a differnt head and the cabinet sounds fine could this be a tube problem or something bigger.
            amp
            Does it have effects send and return? if it does plug a chord from send in to return . see if it works
