I have a friends amp that is acting strangely.
At first it sounded OK, but would cut out with the volume above 4. It has since dropped dramatically. The output is almost nil.
- I have changed the tubes
- I have checked the bias according to info I read in threads regarding TSL 100 Bias. Set to 90mV per side. Bias voltage is -40VDC
- I have tried plugging into the effects loop to see if it is past the preamp. Sound is low there also.
- I have celaned and checked the speaker jacks.
- I have cleaned and checked the tube sockets for contact and cracked solder joints.
The volatge on the power tubes is:
1 - .090 I am assuming there is a 1 ohm R for bais measurment
2 - 3.3AC
3 - 471
4 - 457
5 - -40
6 - NC
7 -
8 - .090
Anyone have any experience with these amps?
Thanks,
Mike
Are there any common
2 - 3.3AC
3 - 471
4 - 457
5 - -40
6 - NC
7 -
8 - .090
Thanks,
Mike
