Hello,
This thread is sort of a continuation of this thread -
http://music-electronics-forum.com/s...&highlight=TTE
However the input DC voltage issue was resolved by replacing the preamp tube in the TTE but the basic hum issue remains.
I originally built the 5E3 last May and had some hum.. did a lot of reading..., redid the wiring until I got the hum to an acceptable level...
I had no effect pedals, (and the sound was great).
Then I got the Fulltone Tube Tape Echo. When I try to use it, the hum is unacceptably loud, to the point that I rarely use it..
Here's the deal - with nothing plugged into the amp, there is a bit of hum - noticeable but not too terrible. If I connect the bright channel to the normal, the hum is less. When I plug a guitar in, then the hum is so low that it's barely noticeable - you have to put your ear to the speaker.
But if I put the TTE in the chain, then the hum is like when nothing is plugged into the amp, but much louder.
In the 5E3, if I pull the preamp tube, the hum disappears entirely.
The heater wires are well twisted (I think) and are tucked away..
Today I redid the preamp grounding, connecting to the main input jack. Actually I think that made the hum worse. Now when you touch the chassis, the hum diminishes. I'm pretty sure that wasn't the case before (the latest change).
Pictures are similar to this except for the changes I made today.
http://music-electronics-forum.com/s...ead.php?t=9164
Again this layout works well except for when connecting with the TTE.
Notes:
- A while back I did the two resistors at the cathode to reduce hum on the heater wiring.. (works)
- brass ground plate is still in place - so grounding is kind of dual to the brass plate, and via a copper wire..
- because of my lack of experience soldering, I could have heated resistors(?) too much, however I've measured them all and they seem ok.
- measure resistance from most leading ground wires and the chassis, almost always at .6 ohms.
I purchased a '70s era oscilloscope, French army I think.
I know enough to watch guitar notes make waves on the screen.
If someone can give me a pointer on what to connect to and what the wave form means, that may be helpful in determining the root cause.
I've learned a lot building this amp, and it has been.. well sometimes frustrating, but in the end very satisfying. I'm determined to get the two - TTE and amp - working together even if it means starting over, or doing a lot over.
My next step I was thinking of putting the heater wiring on a separate battery DC voltage. Should that be 6V? What is the best way to do that?
I was figuring at least it would show or eliminate whether the heater wiring is the cause.
But I think the real issue must be "ground potential" or "ground loop".
Since I've tried, done and measure many things, I'm sure there are details I've left out..
Thanks in advance for your help.
Best regards, Paul
Notes:
Best regards, Paul
