Trying to figure out a problem with the presence control on my 5F6A circuit. I built the amp from scratch using the layout (mostly) from Tino Zotolla's book, and it sounds great. I wasn't getting any change from the presence control, and on closer inspection I saw that I had neglected to make the connection from the speaker output jack to the 27K resistor of the Negative Feedback Loop (NFL). Ahah! I'm sure no one here has ever done that before
. But when I make that connection I get a huge noise, no doubt due to the 15vdc supplied to the speaker from that point. This is my first experience with a presence control and I'm hoping that those here familiar with this 5F6A circuit can help me out. I have triple checked the wiring and everything appears to be right and the amp sounds great and all the other controls work fine. Is it typical to have 15vdc at the 27k resistor? Will try to attach a schematic for the original Fender Bassman. Thanks.
P.S. I have also built a "Two-Stroke" from Dave Hunter's book, and a "Micro Champ" by Adam Alpern (for a harp amp). If I can help anyone figure out something for those circuits.
BASSMAN_5F6A.pdf
BASSMAN_5F6A.pdf
