Hey my helpful friends. This amp has no 6v heater supply on pin 9 of the preamps... I've removed C119 thinking it was the culprit w/ no change. I cannot for the life of me figure out where the 6v supply is...!!?? This schem is frustrating. Might someone show me the way?
Peavey VK100 6v heaters
Do the tubes light up? Then they are getting power.
Look at the power supply on page 9, bottom strip. See "HTR" between R212 and R213? That is the DC supply for the tube heaters.
Now go to page 11 with the output stage. Upper left. Note the four 6L6s and the phase splitter wired for 6v are all in series across HTR1. That tells me HTR must be about 30VDC. HTR became HTR1 when it crossed between boards through ribbon P311.
Note the "6V1" there in parallel with V3. That is a tap in the string.
When it passes through P311 it becomes "6V"
Now lower right on the same page. There are V1, V2, the preamp tubes. Wired in parallel themselves, they are also in parallel with V3, since they are3 connectd to 6V.
So the net result is the same .9A of DC heater current passes through the 6L6s and the paralleled small tubes. There is a filter cap between each tube, most shown upper left, but the last one lower right.
if you have intermittent tube heaters, I'd check that ribbon first.Education is what you're left with after you have forgotten what you have learned.
Do you follow how the circuit works? They ( cleverly, I thought) reailized that the three small tubes used the same current as one 6L6, so they wired the whole string in series across 30v. SO you should have 30v at the HTR end and each tube drops 6v.Education is what you're left with after you have forgotten what you have learned.
I am not sure why they distributed the filter caps like that. Perhaps they found that cathode currents in the 6L6s could modulate the heater supply somehow. So they wouold be a sort of decoupling cap. That is total speculation on my part however.Education is what you're left with after you have forgotten what you have learned.
Should've taken my own advise on this one. EG try stupid things first, new tubes. must've been a bad power tube or PI tube... anywho w/ ALL new tubes the heaters are back. This is a lesson in series wired heaters... try tubes first. thanks enzo.
