Yes... another Marshall 2000 dsp 201 question. I have read most of the related threads about solder joints, and the famous BRIDGE RECTIFYER.
I cut and added a heat sink unit to the rectifyer and that little puppy still gets so hot that you can't hold your fingers on the cooling fins after a few minutes. The 4 fins are 1 inch tall by 2 inches long.
The first time I used it ( after mods. ) it worked for about 10 minutes and the volume and quality began fadding out. I then turned it off for a couple of hours and used it for about 20 to 30 minutes and no issues.
I have checked/resoldered all suspicious joints. Tubes are all looking great. This amp has an amazing sound. It is my first tube Marshall and I can see why people like them even with the " issues ".
My question is 1.....where should I install a 12 volt CPU cooler fan and
2.....how / where to connect it ?
Thanks for being patient with an " OLD " topic.![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
I appreciate the expertise
DOC STITCHES
DOC STITCHES
