Big trouble with modded Peavey C30
  • Big trouble with modded Peavey C30
    Hello fellow Ampagers.
    I have just done a few of Steve Ahola's mods on a Peavey Classic 30 amp.
    This amp is a real PITA to work on for someone with non-pro skills like me, because the soldering eyelets on the PCB tend to ruin at the least touch of iron... Also, it's impossible to test the amp without mounting the PCB back in place totally. This is why I did my mods without individual testing, and now I don't know which mod caused my trouble...
    The symptom:
    the Normal channel does not play anymore, while the Drive channel is affected not only by the Pre and Post pots but ALSO by the Normal volume pot (which is not... normal, actually!).
    It's like the Normal pot was disconnected by the Normal channel and connected to the Drive channel.
    These are the parts replaced with a different value (as suggested by Steve in his http://www.blueguitar.org:
    C18 bass cap;
    C19 midrange cap;
    C14 treble cap;
    C11 boost cap;
    R12 boost resistor to ground;
    C4 cap from V1 to V2;
    C7 cap from V1 to V2 (eliminated);
    C1 and R5 between V2A and V2B;
    R9 grid load resistor to V2A;
    C2 coupling cap between V2A and V2B.
    Plus, I have installed a bias adjust trim pot.
    I have already taken out the PCB and checked all the replaced parts, but did not find any clear issue. Actually most solder joints are not that good (due to partial breakage of the eyelets), but all of them are solid and continuity is where it's supposed to be.
    Will you please direct my troubleshooting towards the potential culprit among the mods I did?
    Schematic and layout drawings are attached.
    TIA,
    Carlo
    Carlo Pipitone
    Take a small screwdriver or a little hook and go down the rows of many little bare wire jumpers that connect the boards together. Gently but firmly pull up on each one. See how many have broken free. repair any that have.
      My thoughts are that a shared ground connection from some of the pots has been disconnected from ground... but that is just what popped into my head.
      As Enzo suggests, check those darned jumper wires!
      Steve Ahola
      The Blue Guitar
      www.blueguitar.org
      Some recordings:
        Hi Carlo
        Welcome to the world of modding C30s
        besides what the others said, also check that you put enough solder on the traces when you soldered the new parts back in. If you can still see light through the holes, you probably need more solder, so you might have to re-flow some of those bits you did. Also check for shorts across the traces where you soldered. (I find de-soldering braid works best for screw-ups in this situation.)
          Thank you guys. I had already checked the points you mentioned, but I'll do it again with more attention to eache and every little detail.
          I'll let you know.
          I'm particularly concerned because this amp isn't mine...
          Carlo Pipitone
            I'll let you know.
            Ouch! Found this contact info at PV, this guy is the most knowledgeable person on PV amps according to many, and reportedly quite nice, he'll fix at the bench for a charge or talk you through it: mikebrown@peavey.com
            (601) 483-5365
              (601) 483-5365
              I don't know... He works at Peavey, I'm not sure he is willing to give email support to everybody who asks for it...
              Carlo Pipitone
                word is ...he is! its good old fashioned USA customer service...a mysterious item..perhaps there is a Wiki entry on it...
                  Fixed!
                  It was a broken jumper resoldered the wrong way.
                  Luckily this caused only audio signal (not high tension) going a wrong route...
                  Thanks to all!
                  Carlo Pipitone
                  casinolevant levant casino
