This one is weird..
I have strange heater voltage at V1-4 , and also V5 . The last 3 el34's are fine. The fuses are good . Good bias and plate voltage , I have no voltage at either side of R69 , (100ohm) and i CANT find R73 (the other 100ohm) . These are in the heater circuit .
Can anyone tell me where on the board r73 is? ive looked for a half hour now!
are these 100ohm a common problem on these amps? I also read about the heater bridge rect being a common problem(or the joints to it) , but why would 3 out of the 8 tubes read ok ?
Heres what im getting at the sockets -no tubes in=
V1 4.7vdc to ground (pins 4/5/9) (no ac)
V2 4.7vdc as above but 9.4dc across 9 and 4/5 (no ac)
V3 2VAC across 9 and 4/5 with 0vdc
V4 2VAC across 9 and 4/5 , also pin 9 shows 3.6VAC to ground
power tubes:
V5 1.8VAC across heaters
V6-V8 -look halfway normal with 7.2 vac across the heaters.
power tubes:
