Dsl 100 Preamp hum
  • Dsl 100 Preamp hum
    Good Afternoon everyone. I have a dsl 100 in for service with a single coil type hum on both channels. Checked effects loop.... its only on preamp side. without an instrument plugged in...quiet as a mouse. Distortion is good on both channels and voltages are fine. I have tried different guitars to rule out the customers instrument to no avail. Even with humbucker pickups...still there...and it is loud enough to be annoying on stage.
    I checked the pop-rivot grounding points..all seem tight. I also Pulled the preamp board and checked for bad solder joints....There were a few..but didnt change anything. What am i missing?? It still seems like a grounding issue to me....(like a guitar cord left unplugged).
    Any help would be appreciated.
    Art
    Have you ruled out the pre-amp tubes? Maybe a dirty jack? You could do a trace of the circuit looking for the source. Use a ground lead with a probe point and ground out all the AC signal points untill you find the right one.
    Now Trending: China has found a way to turn stupidity into money!
      Thank you for your quick reply. Yes, i have changed tubes....Cleaned and checked the jack, The hum originates at v1....i am going to check those wonderful connectors, and go from there.
      Thank you for your time....
      Art
        so what you're saying is if you pull V1 out, hum goes away?
          Sorry i didnt get back sooner tim....had a family thing down in florida. To answer your question...yes when v1 is pulled hum goes away.
          casinolevant levant casino
