I am by no stretch an electrician s forgive my inept description. If its straight forward I can probably fix it but obviously need some help to identify the problem.
This amp lights up but there is no output. I have tried a different speaker and input a signal from the guitar jack and the cd.
The circuit looks good with no obvious dry joints. There is one component which has a slight burn on it looks like a wire burn across it but otherwise it looks fine (and no sign of any other burning anywhere nearby). It is a fairly large white chalky looking tower, I think two legs. It is marked as M7 I1C 270RJ.
There are several of these tower like components the others are marked variously M7 H1C 330RJ and M7H1C R33J.
The burn on this component doesn't look like a showstopper but then I don't know what it is so Identification would be a start.
