I have installed a master volume in a Peavey Classic 30 amp, as per Steve Ahola's instructions. The master replaces the R48 grid resistor on the phase inverter tube (schematic attached).
I did this mod in another Classic 30 before, and in that case the amp developed an oscillation issue that I fixed with a different layout of the master volume wires - see picture attached below: the green arrow shows the correct final layout of the two master wires (indicated in their former wrong layout by the upper red arrow).
Now I have a similar problem: when the Drive channel is engaged, the PRE pot develops a loud fizzy scratchy high-pitched noise (similar to an out-of-tune radio) between 6 and 11 on the dial, while it works fine below 6 and then at 12 (end of the dial setting). The noise is on top of the note, does not replace it entirely. It is not a squeal by all means, just a loud fizzy scratchy noise. The starting point (#6 on the knob dial) does not change with different master and POST settings.
There is no problem of any kind on the Normal volume channel (i.e., Drive switched off).
I have checked the PRE pot with my DMM, it seems fine.
I have replaced the phase inverter to no avail.
I have also modified the master wires layout of course, with no results.
What else should I check?
