working on a jcm2000 tsl 100 watt amp that has a lead channel that is not working. The clean Channel works fine. It appears that pop may have been spilled in around the power tubes. That has all been cleaned and I had all 5 boards out and went through and re-soldered all connections and visually inspected everything. I just got the schem today and will start taking a closer look but have a feeling it may be relay related. Any tips would be much appreciated. Thanks
Marshall TSL lead channel not working
Originally posted by guitaraddict View PostJust got some additional info. Was told that a fuse blew and after replacing the fuse(not sure which fuse) is when the lead channel no longer worked. Dont know if it is significant but thought i mention it , Thanks again
Dave.
