Hi,
It's been a year or so since many here recommended the CompuBias to me.
I finally bought one and today I'm trying it out.
I have a friend's 1975 Fender Princeton at the house because it was physically dropping it's output tubes. I've tensioned the sockets and it seems ok now.
Just for fun I hooked up the CompuBias.
I'm unfamiliar with how the results relate to what I might expect on a Princeton. Can anyone please advise?
Original Issue RCA wafer base Fender labeled U.S.A. 6V6GTA tubes
400vDC
IK 34 W 13.4
IK 38 W 14.9
The Plate voltage and the W figures were pretty wiggly... I had to concentrate to realize the hi and low points. edit to update: I figured out that the Vibrato circuit was causing the readings to fluctuate.
The disparity seemed to follow the tubes. When I switched the tube/probe assemblies in the chassis sockets the results suggested the differences were in the tubes (or the probes). I also switched the tubes in the probe sockets and noticed a slight difference from the original readings... is it possible the probes aren't matched? I attribute some of the noted difference between the first and last readings to the fact that the power caps finally stabilized the plate voltage at 396vDC +/- 1vDC.
I'll suggest to the amp's owner that he buy a pair of NOS Phillips tubes.
Other than that, I'm wondering if anyone thinks the results suggest a need for further maintenance or is this a practical state of affairs? :-)
The amp sounds pretty nice.
best regards,
mike
400vDC
IK 34 W 13.4
IK 38 W 14.9
best regards,
mike
