Electrovoice 81PMX Powered Mixing Board
  • Electrovoice 81PMX Powered Mixing Board
    After needing my mixer fixed I was able to track down a service manual.
    This 200 watt mixing board is a remarkable piece of older technology (early 1990's)
    ... if you have one & need a repair .. contact
    Bosch Communications Systems (USA)
    Pro Audio - Technical Support Group
    12000 Portland Ave South
    Burnsville, Minnesota 55337
    United States
    phone:
    800-392-3497
    fax:
    952-884-0043
    website:
    Bosch - Bosch Communications Systems
    They'll be happy to send you a PDF format manual.
    They have very helpful for me also. I don't know about most of the techs on this forum but a big part of my repairs are for equipment other than guitar amps. Sometimes it's difficult to find schems for older mixers. Right now I need to find one for an old BiAmp 8/29.
      Electrovoice 81PMX Mixing Board
      Well - I just found out that what I got from Bausch was insufficient for my tech;s needs .. so I'm back at square one ... still looking for the schematics for my mixing board ... any help out there ?
      Ted
        Perhaps if you told us what the problem was and what your tech needs?
        Twist, i am looking through my files, I may have that Biamp.
          Maybe not. What about the Biamp do you need. A lot of their circuits are similar to one another.
            Electrovoice 81PMX mixing board
            Here's what I got back from the tech:
            " Problem is the output from the pre-amp/eq section of the board is low. The
            power amp section is working fine. I tested the power amp section using the
            pre-amp output from another mixer - has lots of power.
            Any ideas ?
            Thanks
              So something in the master section is bad. I assume he explored the patch jacks.
                Was that made in Germany by Dynacord like the EV P series pwr amps? If so, you might go straight to them.
                  The Germans make good stuff, but they can't do it all day....
