Hi, I have a Behringer 880S powered mixer that I have has an issue where the Left Main starts cutting out after about an hour and a half of use, The right channel is ok. Opening it up revealed to Amp modules that are ID'd as DPA400 PCB302060REV E. I am wondering if the cutting out could be caused by a bad MOSFET transistor or if something else is the cause. R18 and R19 on the board are slightly darker in the center of the resistor like they have been warm. Also along the block of Aluminum just right of center on the board are 4 components that look like MOSFETS, but are labeled as D9, D2, D7, and D10 on the board.
If I am unable to just order a new board complete, what would be the most likely cause of the cutting out and what are the part numbers for sourcing from Mouser or Digi-key to repair my current board myself... The Numbers on the components are faded enough i can no longer read them.
I really appreciate any assistance anyone could give me on this.
Thanks
Thanks
