Hey guys, I'm new here and had a question regarding troubleshooting a Crate. I recently acquired a 60W Blue Voodoo for next to nothing as the seller stated that the power tubes were bad. When I got the amp the output volume was very low with the channel volumes and master cranked and the sound had some noticeable irregular distortion to it. Swapping power tubes yielded the same weak output, so I decided to crack the thing open and start probing.
Almost everything seems to be in order except for one thing. The B+ voltages are quite a bit higher (more than 50V in many instances) than what they should be according to the manufacturer's schematic. The power tubes (6L6s) measured over 500V on the plates which has me worried. I checked the signal on the grids of the power tubes with an oscilloscope and they seemed to be within the proper range on both tubes. The power section is supposed to be self biasing.
At this point I have no idea exactly what is wrong. Does anyone have any thoughts on this one? Could it be a bad OT? Is the higher than spec voltage causing issues?
