Hey everyone, I recently picked up a non-working and out of warranty 333xl combo from a guy on Craigslist in hopes of it being a simple fix based on most of the issues these amps have.
The problem with the amp is that it blows the fuse where you plug the power cable in everytime you turn it on.
Following some of the threads here and other places, I started checking things inside the amp.
The first thing I did was check the other fuses inside which are all fine. After that I checked the connector going to the board for a burnt pin; the connector had a lot of glue all around it and inside one of the pins and looked like it had a small burn mark on it. I went ahead and snipped all the leads and soldered them directly to the pins on the board. After this I put it back together and it still blew the fuse.
I had read it may also be the power tubes so I replaced all of those with JJ 6l6's from eurotubes and made sure to put the bias switch to the 6l6 setting and I put the bias adjust knob dead center just to see what would happen and it still blew the fuse.
I'm at a loss now as to what to try next.
Any help or advice you guys can give would be greatly appreciated.
