The one remaining problem with this Crate TV-120 is with the volume control. It functions as it should from 10 down to 4, then the rest of the way down to 1 it does not lower the volume, but changes the tone, kind of like a wah.
I thought "bad pot" and removed it from the pcb, only to learn that it tests fine. A gradual 1 Megohm to 0 ohms from the wiper to each leg.
In looking at the schem (portion attached) I see that the signal leaves the volume control and goes through an optocoupler en route to pin 7 on V1. I assume this is to power the channel-indicator LED.
Would a bad optocoupler (this one is a VTL5C6) cause the problem I'm hearing? Or does something else come to mind?
Thanks,
Richard
Thanks,
Richard
