Here's the schem.
http://www.freeinfosociety.com/elect...ertone1474.pdf
O.K., It's not a thunderous noise but the channel two volume pot is really scrathy when it's turned. If I turn it up and leave it it's a little bit noisy but it's only when turning it that it's really bad. I replaced the pot. It didn't help. I didn't read any DC on the pot but I replaced the .02uf coupling cap from V1 anyway, still didn't fix it.
Here's the catch: If I pull V1 and continously turn the pot it will continue to be scratchy for a few seconds and then slowly fade. I tried different tubes.
What could be causing this? The components are a PITA to replace in this guy so I'd thought I'd ask before I do a shotgun replacement of the pre parts. Sorry if that's being lazy.
