Originally posted by kepeb
View Post
Dead Fender Stage 185-replacing thermisto
Also, leave a cable plugged into the input (to keep the mute circuit off) and plug your music source into the power amp input & see if that gets you audio to the speaker. It looks like the Gain Offset knob should give you some control over the volume and also a 3 position Level switch marked Low, Medium, and High. Try changing those controls & see if it makes any difference to the sound coming out of the speaker.ST in Phoenix
ok.
i did a couple of things.
i changed the resistor which was wrong anyway to another one.
a 0.22ohm (correct value) 7w original was 20w but much better match at least
then i checked there was still continuity with speakers cable etc
then i ran a signal in through the power amp in.
the speakers are still completely dead. not a sound. not even a little hiss, hum or buzzing. no click when you turn it on... nothing.
Before we declare U9 dead, let's check a couple of things. Unplug your cable from the power amp input. With the power off, check continuity between R73 and C48. One side of R73 and one side of C48 should be 0 ohms (or very close to it). Without seeing the board, I can't tell you which sides, so just check both sides of R73 to one side of C48, then both side of R73 to the other side of C48.ST in Phoenix
couple of questions.
would the section i am examining now be whats causing the speakers to make no sound at all? seems strange for any amp to have no sound at all. even when idle...?
also.
will the fact that my reverb tank is not connected affect any of this testing or the output?
kev.
The reverb tank should make no difference. It's being mixed into the signal with U8, so it's before the Pre out.
Yes, it would make sense for there to be at least a little hiss from the speakers with no input.
The lack of continuity between R73 & C48 is a problem. What range of the ohm meter are you set to when checking that?
I want you to insert your audio source on pin 1 of U9. Use a small solid conductor wire so that you can touch it to just pin 1 of the IC or clip the audio source onto R86. I can't tell what the value of R86 is on that schenatic. Try it on both sides of the resistor. Be careful with the level of that signal. If the power amp is OK, it's like having the amp turned all the way up - there's no volume control - you're going straight into the power amp.
Then, try inserting the audio onto R149 & R153 - either side. That will tell us whether the power amp is working at all.
How much later are you going to stay up. I'm guessing it's 10pm there now?ST in Phoenix
