Anybody know where I can get the 100 ohm filiment hum balance pot? I also need an input jack for it and haven't found the 5 lug 2 shorting jacks.
80s Fender Concert
Nah the hum balance is a trip pot like the 10k in the blackface fender style and the jack is like a normal fender jack but has 5 tabs and 2 shorting jacks.
What is a "trip pot?"
The AES pot has a shaft, while the original Fender used a screwdriver slot, but a 100 ohm wirewound 5 watt is the deal electrically.
You are looking for a Switchcraft open frame jack with what, five solder tabs? And by shorting jacks do you mean extra contact blades?
OK, I dug out the schematic. The two input jacks have a NC contact to the tip and an isolated NC contact pair activated by the tip. That is circuit XVII in Switchcraft parlance. The jack would be of the 11 series, but I don;t have a number. Fender part number is 019864.
http://www.switchcraft.com/products/..._schematic.pdfEducation is what you're left with after you have forgotten what you have learned.
