Hi this is almost embarrassing
Have a very good condition blackface bassman with the presence
control and a solid state rectifier I guess its the 6G6A which works fine
about 98% of the time.
However occasionally and I mean frustratingly occasionally it drops out and
distorts like I'm transmitting on sideband and receiving the splatter
through a domestic Hi-Fi !
I have had it on the bench for hours and hours with a tone through it
just under clipping and it performs perfectly.
The fault will only show when abusing it by playing guitar at high levels
into a speaker.. doesn't seem to show when driving a dummy load.
Its not vibration - amp on bench speaker on carpet 2 meters away.
Had the amp before and couldn't find it .
Had it approx 5 weeks and failed twice enough to measure that the pre-amp voltage had dropped from approx 22Ov to about 90v.
The second time was able to determine that the entire ht was dropping
but my digital meter was auto ranging all over the place so the figures are a rough guess of the average. (Clue ?) I am guessing it may be one of the tiny elderly diodes as there are no hum issues even though some of the caps are Astron. The H.T. is normally 430/440 volts and seems to drop to half or 3/4 of this.
I'm measuring under the capacitor cover so the choke could also be suspect. Hard to flip it over to check the other side of the choke.There seems to be no way I can induce the fault.
It does correct itself sometimes while playing through it and the owner says turning it off for a short while and on again clears it.
I have used up my entire can of freeze to no avail although it's only 6 deg C outside at the moment so I could rug up and set up in the driveway !
Any clues anyone ? I only see a great Bassman like this once in a blue moon.
Also The owner would like to keep it as original as possible so I don't want to start replacing everything in sight.
He figures an unborn executive will probably buy it for $500,000 in thirty years to put in a glass case ...well considering there is a younger Plexi 50 watt Marshall Head on ebay in Aust for approx $14,000 who am I to argue...
Again any clues gratefully received.
