I really hate to beat this issue to death, having glanced through all the other threads on this amps reverb and realizing that it gets a very poor review, I can't even get this amp to produce the "crappy' sound that several of you have described.
I found that R45 27K was open and R46 had go high in value so I replaced them. When i first examined the reverb tank I noticed that the spring had come off, perhaps sometime before I got it or when I opened it, don't know.
What could have caused R45 to open up? Putting a new one doesn't get the crappy reverb going.
Nor did replacing C18 or C19.
All other resistors measure up close enough to the intended value.
I changed out the 2 tubes and found the original silvertone 6cg7 was weaker than the one had.
Changed the 12ax7 V4 with a stronger one.
All the voltages seem pretty close to practically spot on with the schematic.
No reverb.
The other question that comes to mind is this spring. The one that was in tack has these little card board pieces where they sit over the brass holder.
I cut some more from regular cardboard. Still no crappy reverb
I know it's probably not worth but I'd like to get it going.
thanks for any help.
pete
No reverb.
pete
