MPSU95 sub?
  • MPSU95 sub?
    I need to track down a replacement for the MPSU95...which is apparently rare as frog hairs. MCM lists it but I *will not* pay 35$ for it. Its out of the EQ section of a Messy Booger Mark II....a leg broke off it right at the pkg. Takers?
    AH geez.
    That is the only PNP darlington in that case 152 package, from Moto anyway.
    Look up D40K4. That is a TO202, sort of a big brother to the 152. Same pinout I think.2
    At small currents - which I believe the boogie circuit to be - it has a gain of 10,000, which is remotely in the ballpark. I think the MPSU95 is about twice that.
    And you might be the only guy here to get this - I THINK the D40K was the transistor on the little board on the side of the Deltronics ticket dispenser. Got any of those?
    And the pinout is wrong, but a TO220 TIP105/106/107 might even work. They have gain as high as 20,000.
      I get it I know them well. Don't have any or access to them anymore. I was thinking the WG color X-Y monitor deflection boards might have them but it was in appearance only. OK then.....off to search the parts boards.......
        Did you try Mesa and ask what they use? Best thing to do is ask for the tech that works on those amps. They are very friendly people there and I have found them to extremely helpful...in fact there's a guy named George there that will literally talk your ear off for hours if you let him. Fortunately he's also a fountain of knowledge when it comes to MB products.
        Don't try and call on a Friday though. I think they still work a 4 day work week.
        BTW This place has them for $20
        http://store.americanmicrosemiconductor.com/mpsu95.html
          Try Central Semiconductor - http://www.centralsemi.com/. They make many obsolete solidstate devices and their catalog has a PNP darlington part # CEN-U95. I can not find a PIN out but you could call them and get a few samples.
            I'm working on a Mark IIC. It has no output. I've narrowed it down to the EQ section. It is in fact the MPS U95 - has a broken lead. Mesa says to replace these with MPSA63.
              Or you could kludge a Darlington out of 2 regular 10 cent transistors.
                American Semi has been very good for obsolete and oddball stuff. So have Futurlec and B & D Enterprises.
                $20 bucks might seem like a heavy hit for a single transistor and some people might rig it. I have a penchant for being as close to original as possible in special cases like these. But hey, if the more common MPSA63 is is the suggested replacement (albeit in a TO-92 case), then go for it.
                John R. Frondelli
                "Mediocre is the new 'Good' "
