The amp powers up, but no guitar sound from either clean or drive settings....just slight hiss. When I plug a guitar cord into the power amp in jack...nice loud sound. so the power amp is OK.
i can trace the signal from the input jack to pin 2 of v1...but nothing at pin 1 of V1. i tried 3 different tubes....no change. i resoldered all the contacts on the V1 PCB (socket + ribbon connector wires) and tightened the tube pin sockets...no change. no cracks or broken traces on the V1 PCB.
The 100K plate resistor R4 has 397 volts on the power supply side, 394 volts on the tube side. R11, the 100K plate resistor on pin 6 of V1 has 265 volts on the tube side.
Cathode pin 3 of V1 has .007 volts DC on it...schematic says 1.97V. Pin 8 of V1 has 1.97V on it.
I pulled the main PCB, replaced R4, and resoldered the solder joints at the V1 ribbon connector (main PCB side). no change.
I don't completely understand this stuff, so there may be something obvious I am missing. Any help in conquering this will be greatly appreciated.
